Some days ago I received this faulty Punk Shot PCB (manufactured by Konami in 1990)
Game had small glitches over the sprites and played mute:
MASK ROMs check reported two bad devices:
Usually jailbars mean some problem in data bus so I went to look at relevant circuit.As in many Konami PCBs the sprites generation circuit is condended in two ASICs : the ‘051960’ which generates the address lines for the MASK ROMs and the ‘051937’ which reads data.Indeed I found a missing connection beetween pin 84 of the ‘051937’ and pin 28 of the 8Mbit MASK ROM @K7
This was caused by a broken via on solderside:
Patching it restored graphics, MASK ROMs check successfully performed now:
As for lack of sound I quickly pinpointed the fault in a 2k x 8bit static RAM @E6 (connected to Z80 audio CPU). piggybacking it restored sound.Once removed I had confirm it was really bad :
Job done.
