WWF Wrestlefest repair log #2
 PCB Repair Logs, Repair Logs  Comments Off on WWF Wrestlefest repair log #2
Oct 312016
When switching ON the game, sometimes it had very fast tempo music.
It happened 1 one out of 10 but it was very annoying.
So I used my frequency counter when it happened and I noticed that the 3.58mhz quartz ran at about 10.58mhz!
I changed it with a know good one but again it happened very often.
I was sure it was something connected to the quartz oscillator circuit and given that the resistances are difficult to be faulty I decided to change the cap C47  (33pF) with known good one.
After testing about 30 cycles of switching on and off the game didn’t develop again the problem
Game fixed.
wwf
Liquid Kids repair log #1
 PCB Repair Logs, Repair Logs  Comments Off on Liquid Kids repair log #1
Oct 312016
This game had two problem:
  • Glitchy and noisy sounds
  • Blocky background images
liquidk2
Given the high unreliablity of Taito maskroms I immediately tested the ones marked in red which with no surprice some pins not connected internally
liquidk
C49-04 restored the glitchy sound and C49-02 fixed the blocky gfx.
Replacements to be used are 27c400 (4mbit eproms with maskroms pinout)
Game 100% fixed
liquidk3
Toki repair log #1
 PCB Repair Logs, Repair Logs  Comments Off on Toki repair log #1
Oct 312016
Got this game for a repair which had all screen with washed out colours
toki2
This game has a SEIBU custom named UEC51 which is used as a DAC to output the RGB colours on the monitor.
The input pins were good, but a couple of output pins were fixed, thus creating the images as they had less shades of colours.
I took a good one from another Toki which had other faults and the problem was fixed 100%
toki1
toki3
Diet Go Go repair log
 PCB Repair Logs, Repair Logs  Comments Off on Diet Go Go repair log
Oct 312016
The game had two problems.
First one was the music that sometimes when switching on the game was glitched (very fast tempo or corrupted voices)
The first problem was fixed by replacing  capacitor C7 which was used to reset the chips and didn’t work correctly.
dietgogo
Second problem was some black pixels on some elements of the background.
dietgogo2
After shorting some data lines of the gfx maskroms I found the one responsibile for the background images.
Normally when a markrom fails you get blocky graphics. In this case was only some bad pixels.
Looking on the solder side of the pcb I immediately noticed one pin of one address line of the background image markrom touching the network resistance beside which forced the address line to 1.
diet3
Disconnecting it solved the problem
diet4
Avenging Spirit Repair log
 PCB Repair Logs, Repair Logs  Comments Off on Avenging Spirit Repair log
Oct 312016
Received this game for a repair.
The game had messed background images
avenging2
Shorting some data pins rams I found the one responsible for the tiles arrangement.
I replaced the one marked in red below and it was infact faulty but it didn’t fix completely the problem.
I noticed that the 74ls745 above it was pressed down badly like if it was hit but something.
I decided to unsolder it and test the continuity of all the pads and infact I found three of them (marked in red) that visually were OK but they had no continuity
with the other chips.
That meant that the internal pad was broken so bad it detached internally
avenging1
Making some ugly flying wiring with something I had at hand I tested the game which was fully restored
avenging4
avenging3
