Yet another Truxton II PCB (overseas release of Tatsuin Oh) on the bench and always from Portugal :
The board was stuck on boot on a colored striped static screen :
Main 68000 CPU was not running, both data/address bus were inactive.For first I checked the ‘GP9001’ custom GFX controller (QFP 208 pin ) which is a common issue on hardware that use it:
I found some lifted pins:
Reflowing them didn’t lead to any improvement.The board uses the ‘infamous’ custom ‘HK-1000’ custom (the early fragile ceramic revision) which handes inputs :
A closer inspection revealed the IC was damaged, some pins were broken at package insertion so beyond repair:
As said, the ‘HK-1000’ handles inputs but a faulty one can prevent the game to boot because some CPU address lines are used to generate the enable signals for it.I removed it:
Without the custom the board successfully booted up but obviously game was not playable due not working controls:
So I installed two strips of 2.54mm female machined pin headers in order to host a reproduction of mine:
The last issue I had to fix was some rustling background noise:
With the help of my audio probe I quickly figured out the sound was clean before reaching the 2.2K sound potentiometer :
I replaced it and this restored a clear sound.As ‘icing on the cake’ I removed an ugly hack to use a quartz instead of an oscillator and installed the proper part:
Yes, yet another Truxton II PCB fixed!
Given the extent of the damage the only possible solution was the replacement of the ASIC which is a very delicate operation (not for everyone…) because of its package (208 pins in a QFP package with very fine pitch).For this purpose I’ve been sent by the owner a dead FixEight PCB as donor:
