Ikari Warriors repair log #2
 PCB Repair Logs  Comments Off on Ikari Warriors repair log #2
Oct 052018
Symptoms
The PL1 Ikari character keeps going up on its own when I start a game, the PL2 Ikari is fine.
Looked at my rotary stick, could not see any problems, so I disconnected the sticks from the PCB. The PL1 Ikari character was still going up on its own.
Next I looked at the SNK to JAMMA adaptor, saw no problems here, the fault must be on the PCB.
The PCB is an original SNK three layer PCB set, and uses SNK pinout.
I determined which pin on the edge connector was used for PL1 UP, and traced it back to a SIL resistor array, followed it through a 0.1uf ceramic capacitor where it went to a Hex Buffer 74LS367 at location D4 on the top layer of the PCB stack which handles the joystick inputs.
Bought out the logic probe, and found that Pin 2 (output) on the Hex Buffer was dead. Desoldered it and put the Hex Buffer into my IC Tester which confirmed that Pin 2 had failed test.
Offending Hex Buffer, a Fujitsu branded variant;
Soldered in a new 74LS367 Hex Buffer, all working great now, PL1 Ikari no longer has suicidal tendencies.
The New Zealand Story repair log #3
 PCB Repair Logs  Comments Off on The New Zealand Story repair log #3
Oct 052018
Had a look at a Taito New Zealand Story which was not booting for someone.
Symptoms
The PCB would not boot, would be greeted with a BANK RAM ERROR message, then the PCB would attempt to reboot every 5 seconds.
Had a look at this tiny PCB, and noticed it only housed two large RAMs, a 6264 and a 6256 (HM65256B). One must be for graphics and the other program code, I didn’t bother with schemes to check which was which.
The BANK RAM ERROR message meant either a RAM buffer had failed, or one of the RAMs, given that the PCB used a single large RAM instead of several smaller ones, so the message could apply to a single RAM in this case.
Checked the buffers, they checked out good. Then checked the 6256 RAM at location U31 first, good guess as I found one of the data lines was floating using a logic probe.
Desoldered it, socketed the PCB and inserted a new RAM.
All working 100% now.
Scramble repair log
 PCB Repair Logs  Comments Off on Scramble repair log
Oct 052018
Interesting one this, graphics were doubled up, wrong tiles used and the text was garbage;
I quickly and correctly diagnosed that Bit 0 is stuck low on reads/writes from screen/object RAM.  You can tell by looking at the scoreline;
00001000 = 08 = H … becomes 00001000 = 08 = H
00001001 = 09 = I … becomes 00001000 = 08 = H
00000111 = 07 = G … becomes 00000110 = 06 = F
00010011 = 19 = S … becomes 00010010 = 18 = R
00000011 = 03 = C … becomes 00000010 = 02 = B
00001111 = 15 = O … becomes 00001110 = 14 = N
00010010 = 18 = R … becomes 00010010 = 18 = R
00000101 = 05 = E … becomes 00000100 = 04 = D
I started to look at the video RAM addressing circuit, found a LS157 Multiplexer at 4G used to access a bank of video RAM with pin 9 stuck low.  Removed, fitted socket and new LS157;
Now working 100%;
Terra Cresta repair log #4
 PCB Repair Logs  Comments Off on Terra Cresta repair log #4
Oct 042018
Another on my pile that has been wanting attention for a while. It is an original PCB and is the YM2203 version unfortunately, much prefer the YM3526 version with superior soundtrack.
Which version you have is easily identified by a daughterboard (YM2203) on the underside of the PCB.
Symptoms
PCB will not run at all, all I get on the screen is static garbage which is always the same whenever I try to boot.
I started by looking at the clock circuit, I did this by checking the 68000 CPU’s Clock (CLK) pin which was pulsing as I expected, so the clock circuit must be good. The next thing to check was the RESET pin on the CPU which should have been HI, but it was LO and stayed LO, which mean’t no watchdog system was barking. Pin should have flipped to LO for a split second on boot and stayed on HI for an enabled CPU.
I probed further and checked the HALT pin on the CPU, which was LO, this told me there is a Bus error somewhere and the CPU has put its handbrake on.
Next thing to do was verify the CPU program ROMS (1, 2, 3, 4, 5, 6, 7 & 8 ROMs) were good, as there is no point checking the PCB any further if it has nothing worth running. They all checked out good.
Next I checked the CPU buffers (74LS244), which were inactive as I expected but checked out good.
Ok I thought, must be the CPU RAM (6116) which is bad at locations 10b and 10d, I checked them but they were inactive as I expected, so desoldered them to test them. They both checked out good.
Hmm….at this point I had checked all components on the PCB which would stop the CPU running. I probed further and started to check the Caps. I found a Cap which when I checked both poles with my logic probe, it showed LO for both poles instead of LO (-) and HI(+) which I expected. This can only mean the Cap is shorted. I checked again with a Multimeter which confirmed this.
Off it came;
I soldered in a new Cap and the game came right up!
However, I was not finished yet! Time to convert this YM2203 PCB to a YM3626 version.
First, I removed the daughterboard, you can see the large YM2203 IC on the daughterboard with the Nichibutsu markings on it. The other large Nichibutsu on the PCB is the Z80A for the games sound and soundtrack. Was this an attempt by Nichibutsu to disguise these non-custom components?
Then we need to reburn ROMs 11(15b) & 12(17b) with the sound code from the YM3526 version of the game from MAME. Also, we need to introduce ROM 13(18b).
Next, seat the YM3526 IC where the daughterboard once was;
Job done!
Atari Missile Command repair log
 PCB Repair Logs  Comments Off on Atari Missile Command repair log
Oct 042018
I was recently given a Missile Command to look at for a friend.
Upon firing up the PCB on the bench, all I got was a white screen and the Self Test showed no display but did report a bad RAM which I replaced at M4.
Now the Self Test was reporting a bad RAM at J4, which I also replaced.
No Change.
So, I probed around and found that the LS157 at H2 had stuck outputs.
This was replaced;
The PCB was now running but with graphical issues;
After alot of head scratching and probing, my attention turned to the DRAM controller section.
Here, I looked at another LS157 at M2, which seemed to be working except the output pin 4 (CLOUD2) was stuck LO. Surely this should be pulsing?
I tried to piggyback another LS157 over the suspected failed LS157, but it had absolute no effect.
So I dug out my HP Comparitor to check it out
Also showing pin 4 as bad, looks like this could be the culprit.
M2 was duly removed;
I also tested it in a TTL tester to verify;
Replaced with fresh LS157;
Switch on;
Now fully working.
