Apr 302019
While cleaning the storage I found a very interesting power supply made by Sanwa and marked SNW-7E which works with 110 or 220V
The model SNW-7F is the same model working with only 110V
It’s a very nice and compact power supply ( with a tendency of getting really hot!) and I learned that it was used on the most famous japanese superguns .
When I powered it up it worked but on the -5V line I got -7,5V .
I decided to try to repair it and fortunately the -5V was given by a 7905 regulator with few parts around.
I immediately noticed that the regulator didn’t regulate at all since it passed exactly the same voltage on the input on its output.
Replacing it with a new 7905 fixed completely the problem
Note:
it turns out that this power supply is just a rebadged version of the RT-85A model made by Taiwanese company Meanwell
https://www.meanwell.com/webapp/product/search.aspx?prod=RT-85
Apr 292019
It’s big, black and squared.We are talking of the ’85H001′, a custom IC you can find on some arcade PCBs manufactured by Capcom like Ghosts’n Goblins, Legendary Wings, Section Z, Trojan, Gun.Smoke.It looks like a module with audio functions, two versions have been made.A ceramic unmarked one :
And a plastic/epoxydic one marked ’85H001 5H’ or ’85H001 5I’ :
Technically speaking the ’85H001′ can be considered a nearly complete digital sound system, all typical components (CPU, RAM, address decoder, etc.) are embedded into it with the exception of the ROM and synth ICs which are external.Actually the ’85H001′ has been already reproduced by ‘Apocalypse’ who made an excellent thru-hole version :
You can read more about in his blog :
https://arcadefixer.blogspot.com/2018/02/capcom-85h001-sound-module-reproduction.html
https://arcadefixer.blogspot.com/2018/07/capcom-85h001-sound-module-reproduction.html
Having found recently  a bootleg of Ghost’n Goblins with a module replacement I decided to make my own reproduction and I made two versions.An ‘hybrid’ one with thru-hole Z80 CPU/RAM and surface mounted ICs  :
And a full SMT version with Z84C0006 CPU (PQPF44 package)
Here’s final testing of both on my original Gun.Smoke PCB:
 Posted by at 6:41 pm
Konami ‘501’ reproduction
 Reproductions  Comments Off on Konami ‘501’ reproduction
Apr 282019
The Konami  ‘501’ is one of the many custom ICs you probaby encountered when dealing with PCBs from this manufacturer.Most of times the chip (28 pin 600 mil DIP package) comes with scratched-off part name, sometimes not like on my Rush’n Attack PCB:
It can be found on not so many PCBs like shown on this useful spreadsheet (credits to ‘mattosborn’ on KLOV forums)
https://docs.google.com/spreadsheets/d/1iB9BJaEpAufgKaz758FiDDekUH8JreoTn276yPqD-kk/edit#gid=0
Actually there is already a reproduction of it which uses the ColinD CPLD 28 pin board (based on Altera EPM7064S)  of which ‘Porchy’ wrote the code (available here for download).I simply made what I call a ‘poor man’s’ version using simple surface mounted TTLs gates:
Here’s final testing on the Rush’n Attack PCB:
 Posted by at 5:06 pm
Apr 282019
Some weeks ago I bought this game for my collection in really great conditions.
While playing, I messed up with the external potentiometer of my supergun and menaged to detach it for a brief moment . Result was that the power supply jumped to 7V on the 5V line and 18V on the 12V line.
With my surprise, the game was not totally fried, sprites were still good but all the background was totally black
Also the game had no sound ( but the amplifier was still good)
For the graphics problem, 2k sram @H15 and H16 had all the data lines in the grey area.
Changing them restored completely the graphics.
The sound had also another UMC 6116 sram and the data lines were completely in the grey area.
Changing it led to no improvement but after checking the connections I found out D6 line was not connected to the Z80 but only to the YM2151.
I probably broken it during the exhange. Restoring the line led to a fully working game.
In the end it appears that UMC parts were the weakest devices of the pcb , I replaced all the ones which were present on the pcb
Apr 262019
Code name : ’86S100′.Nothing really ‘TOP SECRET ‘, just a little custom IC you can find on many Capcom arcade PCBs from pre-CPS1 era.To name few :
  • 1943
  • Bionic Commando
  • Black Tiger/Black Dragon
  • Mad Gear
  • Rush & Crash/The Speed Rumbler
  • Side Arms
  • Street Fighter
The chip is a 28 pin one with plastic package and pitch of 1.778mm :
Sometimes you can find it under different part name but same functions, like on a Mad Gear PCB :
This custom IC is involved in graphics generation being directly connected to data bus of the GFX ROMs as shown on Bionic Commando schematics:
Being a not really reliable part (sometimes you can find it literally ‘fried’) and quite hard to obtain as spare I decided to give a try to reproduce it.As usual I looked at how bootlegers re-engineered it and how the custom functions were implemented in earlier Capcom hardware.I succeeded in my purpose it but I actually had to make two versions of it because the original ’86S100′ can work in two modes depending on the logical state of its pin 1 (if hard-wired to GND or VCC).
Here’s final testing of both reproductions on a Bionic Commando and 1943 PCBs:
 Posted by at 7:29 pm
