Got this P.O.W. – Prisoners of War PCB since a long time, bought in a lot of faulty boards from USA :
Board was marked by a piece of tape with the words “SPRITE ERROR”.When I first powered the board up, picture could not sync properly on the Philips CM883-II monitor of my supergun (but it did on my Astro City):
I found a workaround by replacing the 100 Ohm resistor connected in series with the SYNC pin of edge connector with a 10 Ohm one.So the sprite error materialized :
As usual I did my visual inspection and found a severed trace on the solderside (involved in the sprites RAM data bus).Patching it cleared the error so game finally booted showing this issue :
I noticed that if I shorted some address/data lines of a row of eight 2018 RAMs, further lines were displayed so this was the part of circuit involved.
I went to probe each RAM with my scope and found some irregular activity on data lines of the chip @9K, here is a comparison with a good signal (on the left of the below picture)
Time to desolder the chip:
The out-of-circuit test failed :
A good RAM chip fixed completely the game.
