Received this original Moon Cresta PCB (board ‘SMC-2FJ’ manufactured by Nichibutsu) for repair :
Board booted up but some sprites were upside down and partially doubled :
Some Fujitsu TTLs were present so I went through them with my logic comparator.I quickly found a suspicious 74LS08 @6H:
It was really bad once tested out of circuit:
Now sprites were correctly placed but I noticed that the bullets were missing:
Looking at schematics there are two separate circuitries which generate yellow and white bullets.Probing them I found that the two active LOW signals /YBPS and /WBPS were stuck HIGH all the time also when you pressed the fire button and generated the bullets:
The signals are geneated by a 74LS139 @4C:
My logic comparator complained about pin 11 everytime I pressed the fire button and hence activated the selection line B on pin 13:
I pulled the TTL and I had confirm it was bad in that specific gate:
Fitted a good TTL and bullets were displayed again.Board 100% fixed.
