Got this Taito Megablast for a repair:
When I powered it up, I was greeted by a solid black screen, /RESET and /HALT on main 68000 CPU were stuck high.A visual inspection revealed that JAMMA connector was oxidized.Once cleaned it, the board booted:
As you can see both tiles and sprites had sever issues, besided the sound was all garbled and scratchy:
So, for first I went to dump the devices containing tiles/sprites (three 40 pin MASK ROMs 27C400 compatible) and audio samples (two 32 pin MASK ROMs 27C040 compatible) and dumps were not matching the MAME ROM set for the ones @IC32 (sprite data), IC58 (tiles data) and IC29-IC30 (audio samples data) :
Loading my dumps in MAME I could reproduce the issues more or less accurately:
Replacing these bad MASK ROMs with the equivalent EPROMs fixed completely the game.
One Response to “Megablast repair log”
That game always sounded interesting to me. Glad you got it fixed !
These 42pins mask roms present on Taito F1/F2 boards seems to be fragile. I had to replace a bad one on a Thunder Fox as well.
