Picked up this faulty Knuckle Bash PCB on Ebay:
The graphics were totally wrong:
The board use a custom marked ‘GP9001’ @U13 which acts like a GPU generating all the parts of graphics (and video timing signals too)
Package is QFP 208 pin so it’s a common issue to find lifted pins of this kind of ICs after some time.Under a microscope it seemed OK :
But actually a lot pins were detached from pad when I probed them with a needle.Reflowing the IC restored all graphics but colors were wrong:
The palette is generated by two 2K x 8-bit static RAMs and all the 16 bits of color data are latched by two 74HCT273:
Probing the two RAMs revealed a stuck bit (D7, pin 17) on the one @U7 (comparison with an healthy signal on the left of the below picture)
This data bit is latched by pin 13 of the 74HCT273 @U9, piggybacking it restored correct colors:
Chip failed in some gates when tested out-of-circuit:
Job done.
