Another board from the box of faulty ones, an Irem M92 motherboard (with Undercover Cops license seal)
For my testing I used the ROM board from a working Undercover Cops (but I could use a whatever one).On boot I was greeted by this screen, self-test failed reporting errors related to some RAMs
There are two 6116 SRAMs @IC43 and IC44 whose data bus is tied to the two graphics custom ASIC ‘GA22’ and ‘GA21’ :
When I went to piggyback the RAMs, error changed in this:
Probing them with a scope revealed the outputs were dead on both despite the address lines were properly toggling:
Both chips failed when tested out-of-circuit:
With good RAMs the board successfully passed the self-test and entered in game:
But sound was missing at all, I could hear only a slight buzzing noise:
Using my audio probe I was able to verify that both FM sound and PCM samples were properly generated and then pre-amplified/mixed by OP-AMPs but signal got lost somewhere not reaching the input (pin 1) of the MB3730 amplifier.The whole audio section was previously recapped by someone so I ruled out electrolytic capacitors.But a closer inspection revealed heavy corrosion on many 1/8W resistors (probably due leakage of original ELNA capacitors), here are pictures of them taken with a microscope:
Measuring them gave me infinite resistance sign that they were open:
Here in details the bad resistors I replaced:
- R201 – 1KOhm
- R203 – 100KOhm
- R205 – 4.7KOhm
- R208 – 4.7KOhm
- R209 – 2.7KOhm
- R211 – 10KOhm
- R213 – 10KOhm
This restored full sound, board 100% fixed.End of job.
2 Responses to “Irem M92 motherboard repair log”
Excellent work! keep going the good job!
Thanks for reading!
