Mar 252016
Some days ago I had on the bench this Bad Dudes PCB for a repair:
DSCN2505
Board played fine but  clearly had color palette troubles which I narrowed in CPU board by swapped a good one:
DSCN2506
Putting my fingers on board some colors were changing so I could locate the palette RAMs in three TMM2018 chips:
DSCN2507
Probing the chips I found that pin 6 (address line A2 in common) of all of them was completely silent, this was confirmed also by my scope:
DSCN2508
According schematics this signal should come from pin 9 of a near 74LS157 @15H :
TMM2018@15K_address line_2
but I couldn’t measure any continuity with my multimeter.A closer inspection revealed some corrosion on pin 6 of the TMM2018 @IC78 :
RSCN2511ac
I removed the chip and found that the pad was completely corroded and lost contact with its traces:
RSCN2521
I promptly patched them and this fixed the game completely:
DSCN2516
 Posted by at 11:21 pm
  One Response to “Bad Dudes Vs. DragonNinja repair log”
  1. Nice!! Thanks man!
